Hello Mike,
Q. In a U.L.891 switchboard, are you allowed to de-rate the wire or cable inside the switchboard? I have been seeing other manufacturers doing it, so it appears. I've also read somewhere that you cannot use open air values to de-rate the wire. For an example, if i have a 200A disconnect mounted inside my switchboard, normally, per the NEC chart, i would need to use 250kcmil wire(assuming the wire is aluminum). I've seen other manufacturers using 3/0 which is only good for 155A. I'm confussed on this. Can you clarify this for me?
Thanks Dave R.
Thanks Dave R.
