Flex
- poestenkill ny
Anyone else run into emt connectors that have locknuts that dont allow for bushings to be threaded on? Im curious what you all would do to address the issue if anything.
... get some insulated-throat connectors.Get some stamped steel locknuts instead of the typical die cast zinc ones that come with the fittings. The steel are usually thinner.
