T
T.M.Haja Sahib
Guest
It changes the impedance of the circuit. It worked for us on that particular installation. Just something to try if all else fails. I was not there but my help looked for all the typical causes, switched AFCIs, etc. I then talked him thru the process of adding 25' of cable to the circuit. It worked. He settled for looping the hot a couple times around the interior of the panel. Seems there can be a "sweet spot" for AFCIs with the length of cable being a problem. I believe it was a CH tech note that pointed me to that fix.
Increase in circuit leads to increase in leakage current and so AFCI is liable to trip.Above it is stated 25' of cable was added to solve a AFCI tripping problem.Incomprehensible!
