tim89s
- Brush Prairie WA
Is it ok to strap low volt cable to emt. Code sec 300.11(B)2 states you can. Code sec 800.133(B) states you can't. I am trying to link several industrial ovens together so they can be monitored and controlled via a computer. The low volt cable would only be strapped to conduit directly associated with a oven. The cable is a 1.5 pair with shield. The cable ties into some sort of module then then is linked to a computer. Code sections referenced are from 2008.
