gar
- Ann Arbor, Michigan
- EE
120120-1239 EST
TED displays two patent numbers on their 1000 series system. These are 6,226,600 issued May 1, 2001, and 7,043,380 issued May 9, 2006. Almost identical wording is used in various parts of both patents.
In reading the broadest claims, and with some reading of the description, I do not believe the patents read on the product to which the patent numbers are attached. I do not believe this is allowed.
The only area I was considering was the MTU (Measuring Transmitting Unit). The way the claims seem to be worded is they all seem to include an MTU that has at least two current transformers, each current transformer individually AC amplified, followed by conversion to DC, then summed. In one claim they did not sum the currents until after carrier current transmission of the data.
What the actual MTU I have does is:
Connect the current transformers in series, properly phased for their intended purpose. So this is where the summing is done. Before amplification.
A differential amplifier in the Cirrus chip then amplifies the already summed AC currents. Actually a voltage at this point.
Next the AC signal is processed in at least two ways.
I do not see where any of the claims would read on the way TED and Cirrus process the data.
Thus, I do not see how either of these patent numbers can be displayed on the product. There is no statement that says none or more of the following patents apply. In fact it implies that both patents apply.
Anyone else with an opinion.
