Alwayslearningelec
- NJ
- Estimator
Ok, this may be one of my "dumber" questions. If you have 3 light poles on the same circuit next to each other about 50' apart and they want a separate neutral and ground would you only pull the ground and neutral to the first light pole and only extend/splice only the hot or would they N&G have to be spliced as well and run to each pole? THanks.
