bilwei
- Lufkin, Texas
We have a 4160 volt motor that we are going to replace the feeder wire. According local plant knowledge - supposed operating voltage is; Phase to phase is 4160 volts, phase to ground is 2400 volts. We cannot confirm the actual voltage at this point. The existing wire is non shielded. In applying the NEC 310.6 for shielded and non shielded cable; I am some what confused. Do I apply article 310.6 based upon the phase to phase voltage or phase to ground voltage? If I divide 4160 by the square root of 3 to get the phase to ground voltage it equals 2401.77. Acception to 310.6 allows non shieled cable up to 2400 volts. So do I use shielded or non shielded cable?
