BullsnPyrs
- Saint Joe, Arkansas
you can also change to a ballast with a higher ballast factor to increase the actual lumen output of your lamps. Just be sure to have adequate circuit ampacity for the higher power consumption.
And I find ballast life on the T-8 are shorter then the magnet ballasts .I find T5s to be less reliable, both lamps and ballasts. On top of that they are more expensive.
I also find that customers have a hard time knowing if the fixture needs a HO or regular lamp.
From what I gather, it's mainly do to heat in a poorly designed fixture. T5ho's have a very high output in what are usually small fixtures, so I would say that a correlation could be drawn. I haven't seen many T5 failures other than cheap ballast failures. The bulbs themselves also have a high output in a small fixture, so heat again is a problem to consider, though I haven't seen many T5 bulb/lamp failures to warrant concern.
And as for electronic ballasts having a shorter life expectancy than a magnetic ballast, it goes against the design of the ballast. Theoretically, an electronic ballast should have a far superior life. But as we know with electronics these days, manufacturing quality isn't quite up to par. There are far more failure points in an electronic ballast as compared to a magnetic ballast. The pathetic amount of "new" T8 ballasts failures that I have seen is unparalleled by 30 year old magnetic ballasts. Again, I say poor manufacturing quality/standards.
(just my opinion)
Can T5 HO fittings replace high bay fittings?Thanks.
In Philips lighting design manual (old edition),it was stated that ordinary fluorescent fittings are not suitable as high bay fittings.Generally if replacing Metal Halide or HPS high bay fixtures they will be hung from a hook with a twist lock cord and plug if wired to the commonly used method done here in the states, It allows a fast method of changing out a defective fixtures, it also makes it easier to upgrade the fixture to the new T-5 high bays by just installing the hooks to hold the light up and plugging it in.
Is the higher the kelvin # the brighter the light?
Here the problem is if two light sources, having the same wattage,will have same light output i.e brightness,if their Kelvin temperatures are different.An example of this would be a 150 watt tungsten bulb is brighter than a 25 watt tungsten bulb but both have the same kelvin temperature.
