With all the recent power outages due to storm activity I've recieved several calls for generator power back up systems.Most of these are simple and small units.I have one upcoming that is somewhat different,the owner has two generators ready to be wired to the home.This is a 600 amp service with 3 -200 amp main lug indoor panels.
The retrofit is difficult to access the circuitry due to this being an after thought.My question is other than possibly using a wire gutter under each load center is there and exception to where it's permissible to nipple through from one panel to the other to obtain the critical circuits?There is two ATS and they each are a 20 circuit factory wired unit with the flexible conduit whip attached.My third panel as well as a subfeed lighting panel is presenting the issue.Any thoughts or ref. points is much appreciated.....
