Is coordination possible for Breakers on the synchronization bus and Emergency Bus of the building. The DG system comprises of two parallel feeding Generators. A fault in any Substation kills the emergency supply by tripping both DG simultaneously. The DG incomer breakers are of lower capacity than the outgoing breakers of the DG bus. The breakers at the emergency bus are of same capacity as the outgoing breakers of the DG Bus.
Is there a way to coordiante breakers so that a fault downstream will selectively trip the outgoing breakers and not the both DG.
