Inspector Barry
New member
- Hanford, Ca
Recently, the Utility Co. pulled a meter that serves a Fire Pump. What kind of label could/should there be for the Utilty or Owner to know about this?
Not around here. Fire pump services are metered just like any other service in this area.IIRCC, service taps for fire pumps are usually ahead of the meter; what happened here?
Hmmm, so if the meter is pulled for whatever reason, and the building burns to the ground because there wasn't enough water pressure at the sprinklers, who's going to have the really bad day in court?
About the only way the utility would be in trouble is if the meter was pulled in error.Hmmm, so if the meter is pulled for whatever reason, and the building burns to the ground because there wasn't enough water pressure at the sprinklers, who's going to have the really bad day in court?
