He says the ballasts are labeled "programmed rapid start". So then what is the difference between programmed start, and programmed rapid start?
well, there is rapid start, instant start, and programed start.
instant start keeps the filaments on and warm all the time. not efficient.
rapid start isn't as fast to light up, draws less idling power, lamps last longer.
doesn't like high cycling rates.
programmed start is in between those, and is designed for energy saving systems
where they lamps are cycled on and off a bunch... so, technically it *is* a rapid
start ballast with a faster start optimized for high cyclic rates... the word rapid
in conjunction with proigrammed, i'm suspecting is a lot like "new and improved"
to an advertiser selling spin.
