- Massachusetts
I am going with around 30 x 30 but it IMO depends on the lay out of the conductors and how that affects the 12" that will be required between entries of the same conductors.
Then I would say 30x34
Calculate 22x18 but I think you need to add 12" to keep the pipes apart.
Yep- I was still thinking 4 instead of 6 on the one side 22x22 but I would give some room for bending - 30x30 would work depending on how they are laid out. If all the pipes were grouped as far away as possible then a 22x22 may work also. I would love to know exactly how this should be.I get 22 x 22 and 'some distance' to keep the pipes apart. consider if the 12" measurement between entries is at 45 degrees relative to the can the extra distance needed on each wall would be 6"
Do you agree there should be 12 inches between the conduits for the bends.
