ELA
- Electrical Test Engineer
Can anyone provide an estimate or approximate range of secondary inductance for a typical size residential area transformer (7.2kV/240V)?
I am interested in the inductance value. Understood it may vary over a range based on other factors. Thus a range would also be good.
Or the secondary impedance ( @60HZ across full secondary) if I can then use this value to back calculate the inductance, so this value can then be used to estimate the impedance at other higher frequencies?
In particular I would like to estimate the impedance that a frequency of 131Khz would "see" when attempting to flow through the secondary.
The 131Khz originating inside of a customers home and traveling out to the transformer via one leg. I want to estimate how much might be expected to return on the other leg back into the home ( ignoring the center tap initially as well as service conductors impedance). If a value is known, can secondary to primary capacitance be ignored in this calculation as insignificant or not?
Hope this is not too vague, I am just trying to get a ball park figure.
