If the power supply has a cord and plug, I would think that it would not be compliant.I know you can not plug anything in to an outlet above a drop ceiling but if you put the outlet in a pullbox would this be code compliant? I have a small power supply that needs to plug in.
I agree. The cord may be above the ceiling but it is in a enclosure just as our circuit conductors are so I don't see an issue. I am sure there would be some ahj's who would argue that it is not compliant.IMO if the cord is within the covered pull box then it's compliant.
It is actually for a power supply for an antenna system.
You probably right that some inspector would find an issue with it. But IMO it's still code compliant. :thumbsup:
It is clearly still above the ceiling within a box or not.
IMO a violation.
Does it have to be a hoffman encloser or can it just be a screw cover pullbox?
Can you run non plenum grade telephone wire in a conduit in a plenum?
400.8 Uses Not Permitted. Unless specifically permitted
in 400.7, flexible cords and cables shall not be used for the
following:
(5) Where concealed by walls, floors, or ceilings or located
above suspended or dropped ceilings
IMO a violation.
Oh, the pox on that. The main danger of cords is deterioration of the insulation that would cause a hazard in these spaces. The cord would be in a bonded enclosure that would be no hazard since it is contained and can be inspected.
Again, I have not said I think it is unsafe. I do think it is clearly an NEC violation.
