[FONT=MS Pゴシック][/FONT]Thankyou templdl,
[FONT=MS Pゴシック][/FONT]NowI?m planning to use a 1 phase more than 40kVA control transformer supplying120V for a huge machine system. But 40kVA sounds unusual as a controltransformer, so I?m checking if this capacity would meet NFPA and / or ULrequirements, if this would violate them or not. And I find the clause 9.1.1.1and 9.1.1.3 from NFPA79, which seem to have relations with my question. HereNFPA79 has set the criteria for the need of transformer to available shortcircuit current 1000A rms. 40kVA transformer of course should supply far morethan 1000A in short circuit, and taking 120V 1000A available short circuitcurrent, the control transformer rating would be more or less 5 to 6kVA at a maximum. Meanwhile I also find in the NEC theArticle 725 concerning Class 1 circuit, here in clause 725.41(B) Class 1Remote-Control and Signaling Circuits, it says ?The power output of the sourceshall not be required to be limited? Taking this, the control transformercapacity has no limitation literally. I?m not sure how to think about this, socould you advise me ?
