sdkokx
- Grand Rapids, Michigan
I have a 14"x16" Motor Starter box. If I jump of the line side of a 208 3-phase Motor Starter to a 208/24v 100kVa Single Primary transformer with fuses for both H1 and H2 do I then need to bond X2 to the ground bar inside the Motor Start box? I've been searching and I can't seem to find an answer with this set-up. I've attached a picture that can hopefully illustrate better than I can explain. Thanks.
