I had posted last night regarding a boat lift that i was going to take a look at today.1/2hp single phase motor SF1.15 wired at 120V. Nameplate is 8.5A, obviousley there is a gear reduction unit attached to it. Lowering the boat I get a reading of 8.2A on my meter, no problem the boat lowers about 40" and is in the water. Lifting is attempted, amperage is at 14 to start and remains fairly constant for about 30", at this point the load starts increasing progressively 15,17,20 etc. all the way up to 30 and the motor simply stalls no trip on the 20A CB.I notice that the steel cable at this point does not look like it is wrapping around the drum in a even manner(crossing over and laying atop the cable not next to it).Would the way the cable wraps on the drum cause an excessive strain on the motor? Also, with the proper gear reduction for the weight being lifted isn't the 14A load that is occurring on most of the lift already quite high?Owner states that in the 4 years he's owned it it has never worked what he would say was right(used unit with no manual or lift rating).I checked VD and found it to be running at about 112V while it was lifting the first 30" or so. Owner had a portable generator that he set about 120' from the lift and used a #10 cord, the motor still pegged at 30A and simply stalled. Any thoughts? Thanks.
