williamsmithaud
I have a customer with 2 2 4 Triplexed URD run underground through 1 1/2" inch PVC conduit. I have to pull another 4th (ground wire) through this conduit. The problem is that both ends of the conduit have been filled with spray foam insulation.
Can anyone tell me how to dissolve or remove this foam (without damaging the PVC or insulation on the wire) so I can pull the other wire through?
