Ok this is what I want
I guess you misunderstood the original question if not I cannot comprehend that article
Thanks any ways
The distance between thE 3" must be at least 18" then the distance between the 2" must be at least 12".
The way you have yours set up and If my math is correct I say you need to have a pull box or gutter that is at least 42" wide.
However if you install the 2" on the inside and the 3" on the outside you can get away with 28" wide pull can.
Thanks for help
Would you mind explaining how do you get the 42 and 28 dimensions
Best regard
i mean metal enclosure :ashamed1:what is a meta enclosure anyway?
If you were to stack the 2" in front of the 3" ......... of course will need to be physically deeper to accomodate stacking them.
