1970 nec question
does anyone know if a multi-unit housing unit(24) built in NY in 1970 with a main circuit breaker installed after the meter for each unit requires the grounds and the neutrals to be seperated in the sub panel in each apartment?
480sparky
Iowegia
Not everyone who can answer your question is online 24/7.
Not everyone HAS codes from 1970.
Not everyone here has NY codes.
jxofaltrds
Inspector Mike®
Mike P. Columbus Ohio
ESI, PI, RBO
So you have a "main" breaker then a 3 wire system to the apartment panel?
I don't have a problem with that 1970 install.
What is your concern about the install? Legal or safety issue? Sounds like it is both (OK).
