The project is adding a generator tap box to an existing switchgear.
MDP, PD-1 east and PD-1 west are in one enclosure as the sketches depict and not the drawings
DS-G1 and DS-G2 will be mounted next to each other and almost equal distance from MDP
The design incorporates and Kirk key system that will not allow the generator and the utility to feed the load at the same time
"backfeed concern.pdf" depicts a concern by the engineer that the current derived from the generator will backfeed to the generator (as depicted by his arrows). The reviewing engineer does not see think it will (he did sketches A and B)
"mark-up of sld 1.pdf" shows better what the proposed new equipment is to be installed (in green highligher)
"sld sketches A.pdf" shows the sld with utility powr a bit clearer
"sld sketches B.pdf" shows the sld with generator power a bit clearer
Please let me know your opinion and feedback. thanks for the help
