Alwayslearningelec
- NJ
- Estimator
If you had a homerun with (10) 1pole 20A circuits and the spec did not say isolated ground, separate neutral etc. would your wire counts be the following: (10) hots and (3) neutrals and use the conduit for the ground? These would be feeding receptacles or lighting not motors.
If there were isolated grounds speced for each circuit you would have (10) additional isolated ground wires??
Thanks
Thanks
