Class 2 Wire and Pipe Fill
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
I believe I would try and find the actual dimensions of the cable itself. You may be able to look it up online or contact the manufacturer. Then using Chapter 9 tables you can figure it out. I am not sure those conductors are included in this table but that is what I would use.
del91574
ct
Conduit fill does not apply, nor does any chart, other than cross section, in the NEC.
There's basic items that can be figured via circular mils and similar.
