I work at a rubber mill, large 150hp dc 500volt 245 amp G.E. Motor, installed around 1967. I was born in 79.
so my regular pm, checking brushes and the like, i notice the commutator is shaped like a horse shoe, the brushes had finally eaten down about 1/8 inch? or so. So I called in a Motor shop Tech, cause i want a real experienced opinion. He's like yep needs worked on. no problem, we shut down the line, send it out, get it back, and 45min into running it starts shooting green (brass/copper) flames out of the vents. the operators obviously shut it down. we tear it out sent it backout, today it comes back cleaned up again. exact same senario except im standing next to the disconnect this time ( i was away the first time) about 40-45 min into running the motor I hear it wind up like a turbo motor and as im pulling the disconnect i see the aforementioned green spark.
I have tach feedback checked and doublechecked:?, any ideas? the drive is a 590 series eurotherm, absolutley no alarms. it has field loss enabled, feedback loss enabled, overspeed enabled. the only thing i regret is I didnt have the presence of mind to look at the armature amps as i was pulling the disconnect.
any ideas, conjectures, theorums, things to check would be greatly appreciated, the main motor controls guy from the motor shop is coming out tomorrow. hopefully he can diagnose this.:happysad:
