Sheetrock is quick to fix but the exterior of the building is stuco. That isn't so easy to fix and its unexceptable to the customer to be bashing holes in it
The only access I have, to get to structure, is a hole about the size of a round box. I was thinking that a tool like this might help...but wasn't sure
Thanks for the replies
this might get you there, but you'd have to drop the $$$ for the drill, as the accessory only fits that drill.
however, once you get past the sticker shock, that drill replaced every drill i carried on the truck, including
a corded 1/2" hole shooter. comes with drill, 90 angle, offset for drilling close into corners, charger, and
two batteries... you really don't need more than two batteries. it'll charge them faster than you can run
them down. if you chuck it up to any other drill, and "arm wrestle" them, it'll spin any other drill on the
market backwards, with smoke coming out of the other drills vents. don't do it to a dewalt. it kills them. :happysad:
the only other thing that comes to mind is a dversibit. maybe you could put a short flexible one thru the hole
and get drilled what needs drilling ?
http://www.greenlee.com/products/BIT%40cD'VERSIBIT-%40.250X%40.187X36%40.00%22C%22.html
