Number of wires includes ground?
cppoly
New York
Basic question here, does the number of wires listed in a product data sheet include ground?
A datasheet says the electric requirement is 220V - 3 wire but doesn't specify single or 3 phase. Single phase could be 2 hots + 1 ground to satisfy 3 wire. Or 3 phase could be 3 hots to satisfy 3 wire if the ground isn't included. Does the NEC have a standard on this?
Also, this equipment is for commercial buildings, so shouldn't the voltage be really specified at 208V? It's a violation to provide the wrong voltage for equipment. B/c after voltage drop the equipment might only see 200 V...
don_resqcapt19
Illinois
retired electrician
In general, the EGC is not counted when you see a spec like that.
A grounded conductor would be counted, so that spec could be for a three phase system with three ungrounded conductors, or for a single phase system with two ungrounded conductors and a grounded conductor.
realolman
That's a pretty crappy non-specific spec IMO... why would anybody even write a thing like that?
Smart $
Esteemed Member
Ohio
Some manufacturers choose to indicate equipment that will operate on either 240V or 208V systems as 220V, as it is within +/-10% of both.
