Looking for input on what constitutes a "pole" when applying 2011 NEC 600.5 (c) (3) which allows poles to be used as raceways. Some signs are obviously using poles, but some signs use an i-beam enclosed in an aluminum or plastic shroud. Would you allow open single conductors in this situation?
I personally think the exception was only intended to allow an actual structural pole to be used in lieu of raceway. Wrapping an interior support in aluminum does not make it a pole or provide much protection IMO. But there is no definition of what a pole is or what thickness the metal should be?
