Well forget the above statement on the fixed generator set as the prices went up drastically since I last looked at them, this
10kw Generac with the 100 amp ATS panel used to be around $1200.00 to $1500.00 just a few years ago now is over $2700.00:rant: I still like the fact of the cleaner burning NG over petroleum as even the oil doesn't get dirty and you can go 2 years on synthetics for oil changes, but you do have to derate the gen set by 1kw on NG over propane or petroleum gas, even though they use the same engine/alternator on both NG or LP.
I plan on maybe getting away from the inverters/batteries I'm using now as they will only give me about 8 to 12 hours of back up (except the computer and home theater) and plan on getting a 15kw whole house with a ATS I just wish they made a inverter output gen set at that rating as when there is very little to no load the engine can slow down and very its output based upon the load being drawn without changing the 60hz frequency, it would be a big savings on fuel, an optimum system would be inverter out with the option of batteries to give an instant power availability like a UPS system and have the engine only start start and run as needed when the batteries get to a certain point something in the line of the newer hybrid cars, the alternator would be set to just charge and maintain the batteries, something in the line of a 36 or 48 vdc system, but it would be a expensive system to buy, but would save a lot more on fuel.
Might be worth it in an area that suffers from frequent outages, but I live in town and I have four sub stations that we can be supplied from, so outages are very rare and if they do happen its only for a couple hours at max, all though back several years ago we had a bad winter storm in march that we didn't have power for 4 days so it can happen.
My problem is my drainage system for the foundation, the drainage was an after thought and they installed a perimeter drain pipe around the outside of the footer and brought it into a sump pit under my stairs in the lower level (bi-level) when it rains that sump runs constantly, if it quits it can flood my basement which is completely finished with a large family room with fire place and bar and bedroom and bath, I have two pumps in the sump (one higher then the other) for a back up it used to have a 12 volt pump as the back up but it was to small and would never keep up, so I installed two new pumps one 1/2 and one 3/4hp, both now are backed up via inverters but like I said the batteries wont last over 8-12 hours so it is a worry for me if I go on vacation.
