Series Circuit Question
ActionDave
Chief Moderator
Licensed Electrician
... Unless source impedance was important (which it is not for the point being made in the graphic), I would have just shown a 120 volt source. If asked, then the depth of coverage would depend on the audience....
There you go. No need to tell somebody how to build a watch when all that is being asked is the the time of day.
What goes in comes out.
Which leads back to this:
Let me see if I can simplify it: The sum of voltages around a loop equals zero. If you sum the voltages in the diagram you don't get zero you just get all the voltage drops. What is missing is the EMF source (the voltage rise) that produces these voltages across the resistors displayed.
I like this explanation the best so far, tells us what is going on yet is not too complex.
Think of the rise as a positive number and the drops as negative numbers. You could even place additional rises within the circuit and it still works out.
The impedance of the source is going to be a drop within the source, it will not be a fixed value like a resistor it will vary depending on the current.
And yes we run into this every time we calculate available fault current.
