250.96 Bonding Other Enclosures.
(A) General. Metal raceways, cable trays, cable armor, cable sheath, enclosures, frames, fittings, and other metal non?current-carrying parts that are to serve as grounding conductors, with or without the use of supplementary equipment grounding conductors, shall be bonded where necessary to ensure electrical continuity and the capacity to conduct safely any fault current likely to be imposed on them. Any nonconductive paint, enamel, or similar coating shall be removed at threads, contact points, and contact surfaces or be connected by means of fittings designed so as to make such removal unnecessary.
FWIW,
that are to serve as grounding conductors, the non metallic expansion fitting is installed then it can not serve as an EGC, hence, we install the EGC (conductor type). Now, as far as "be bonded where necessary to ensure electrical continuity" the metallic conduits are bonded at both ends.
