woods95662
- sacramento
Can I use shielded tray cable in liue of VFD cable? There would be multipal runs of this cable in a gutter. I would think it would be ok but never like to assume anything. Any help would be appreciated.
Thanks for the replies.
I didn't find the PDF you were talking about, but they do sum it up pretty well on the main page:
....There would be multipal runs of this cable in a gutter....
what does this part mean? sounds like you would have more than 1 set of vfd driven motor leads tossed in there together?
Just curious how many motors worth of cables will be in the same gutter if so?
If this is the case, I wouldn't go without an individual vfd shielded cable for each motor as you may end up with interaction between the various motors that cause you much more cost tracking down and fixing than the initial investment in a bit more expensive cable.....
Fixed it for ya.Hi guys I had no idea this had been posted and replied to I didn't receive any notifications. I got it figured out and I appreciate the help! Basically it's the safe bet to just use VFD cable unless it's the only cable in a single STEEL conduit in which case you can just use THHN. Otherwise you're taking chances running multipal cables in a conduit for a VFD and not using VFD cables. The extra shielding in VFD cable gives you that extra protection plus it carries a full size ground.
