dwhensley
- Charleston, SC, Charleston
I have two existing transformers one goes from 13.8kV primary to 480V secondary the other goes from 13.8kV primary to 208V secondary. The customer wants to start putting all electrical equipment on platforms to get out of the flood plain. We are using the existing pad mounted xfmrs which have the space in the bottom to stub up conduits. When these are elevated the transformers will be open on the bottom so we want to put a galvanized box on the bottom that we can connect the conduit to. With that said when this is done the medium voltage and low voltage cables will be in the same box as the wires to up to the lugs on the transformer.
Is this alowed since will technically be two different voltages in the same box?
