bullheimer
- WA
i guess there is no way this thing is ever going to pass code so i just want to make sure i don't kill anybody. i only pulled a permit for this remodel job, i did not know there was going to be a trailer there until just the other day, at a pre construction meeting when the Port guy asks me to hook up this trailer they got for the longshoremen to take breaks in while the old place is under construction.
the trailer has an overhead service mast! the old building is being fed from overhead 3 wire. they own the wires and use the power companies sizes, i guess, as it sure isnt 4/0. the building was built in the 60's hence the 3 wire, because this is fed from a breaker in a disconnect some 150 feet away! i could find NO ground rod and assume its under the brick or slab.
i said i would do it so i did it: i hooked up 3 wire aerial to this trailers mast. i did not notice the green ground wire in the mast till i bought the wire, but there isn't anywhere to hook it up to, on the pole anyway! the 3 wire overhead obviously doesnt have one, the old building, obviously, has the neutral and ground bonded together, so i think it would therefor be pointless to run a ground wire to the buildings panel.
With my circuit tester, ALL the outlets in the trailer said they were grounded!!! i can't explain this. other than pouring rain and the tongue of the trailer was on the wet ground. i took voltage readings from the frame to the ground and zero. i felt them both, nothing shocking. And, i got 120V from the hots to the isolated (as far as i could tell) ground bar, as well as 120V from hots to neutral.
so i figured, since they must be bonded somewhere, somehow, and i did not want the green wire just hanging out of the weather head, i connected the green ground wire into the butt splice with the neutral. everything works fine.
i am worried that i need a ground rod and should separate the ground and neutral. this will never pass because there is basically no way i can find a ground anywhere, and the main breaker is at least 100 feet physically and 160 feet electrically from the trailer.
can anybody tell me what to do and why. i read a 4 page post on this here and got two differing sides squaring off. and like i started this off, i dont care about the code, i just want this trailer to be safe. (right in front of it in the rain are extention cords and more extension cords plugged into octopusses NOT plugged into a gfi recept. this building has NO gfi outlets outside.) i just did this today and need your opinion. THANKS. my worry is maybe the trailer was grounded from the rain, and as soon as it dries out (in june) there may be a shock hazard.
ps, there are NO sleeping quarters and NO cooking equipment. only appliance is a hvac unit. no bathrooms either.
