mstrlucky74
- NJ
If you had a run from a comm room to a table top box and instead a running one direct rum from the patch panel to the device you instead run to a consolidation point/patch panel near the device and run a patch cord 15' away to the device where would you be responsible for testing that cable? On up to the consolidation point or also the patch cord? I thought maybe since the patch cord is pre-fab it might be pre-tested as well thus alleviating it from being tested in the field. Thanks.
