Is there a hand bender for bending multiple pipes at once?
I know there are shoes for a 555 bender for multiple conduits at one time but what about a hand bender for two or more 1/2 EMTs or maybe two 3/4 EMTs
Looking for a faster way to bend a lot of 90's
I worked for a company that had a bender that had two sizes 1/2 and 3/4 it was heavy in comparison to a 1/2 or 3/4 bender and no one used it.
need an electrician ? happy new year , really. how many you need to bend ? when i was piping, we'd have a guy in the air (lift/ladder) and a guy on the ground, or we'd put a man and his pipe and his bender in a lift, depending on the situation
IMO, if you had dual hand bender, in the time you'd have involved getting both conduits in position to bend, and then bend them, you could have bent two conduits one at a time.No saddles or offsets that wouldn't work with two attached hand benders.... If I'm going through the motions of bending ( a crap load of 90's for data for instance). ill do two at once
I saw a bender in a folder that could do offsets in 1 bend. I forget what it looked like in detail. Folder said put pipe in bender & apply foot pressure. Supposed to make the perfect offset. Greenlee, I think.
You must be thinking of a "box" offset. I have used these on different jobs for years and they do make a perfect box offset and it does save time.
Trying to bend 2ea. 90 degree bends at once with a hand bender probably wouldn't work so well or save time at all. You would still have to measure and fit the conduit into the bender and find some method of keeping it straight ( two at once ) and this would tend to slow things down.
If you are running a lot of exposed conduit then try the offset bender because it's fast and every box offset is exactly the same and make a job look better if the guys are not that good at bending box offsets.
Yes....
Does Greenlee still make it?
