mopowr steve
- NW Ohio
- Electrical contractor
Help with a straight forward answer on how to calculate the available fault current at service point. So far I have found a fault current calculator on line that shows both line to line fault current and line to neutral fault current which one of these values are used for the label or both?. Paperwork from the power company shows 44,040 Max short circuit amps at Ph. to Ph. volts for the transformer they have installed, is this the correct value that I start with when beginning the available fault current calculation? When using this information along with the conductor size, length, material and conduit that was installed it showed me 39,592 amp line to line and 52,905 line to neutral , with that being said; if the breakers installed in a main lug distribution panelboard (with 6 or less disconnect rule for service equipment) rated 200,000 sccr and breakers with a aic of 22,000 do I need to replace the breakers with a higher aic rating? and if so which value do you use the line to line or line to neutral?
