joebell
- New Hampshire
There used to be language in this section requiring simultaneously disconnecting the ungrounded conductors of a multiwire branch circuit supplying a free standing type partition. I have read the proposals that changed this section and removed this wording and understand the basic premise. My thought however is the actual connection to these types of partitions, commonly these connections share the grounded conductor between 3 ungrounded conductors. If I pull a cable with 3 seperate circuits each with a seperate grounded conductor and the fitting used to tie into the system is as I have described above do you need to provide a means to simultaneously disconnect the undgrounded conductors?
