ryanpickett2003
- Hilliard, FL, Nassau
Good Morning,
I'm neeeding a little help understanding a situation I was called to yesterday. I have a customer who has a mental health facility. It was an motel converted to this facility so all the rooms are in one long line. Each room has a 220 volt window A/C and Heater. They were having issues with one of the AC units coming on and off. Once inspecting the issue was a bad connection. The problem is how to properly repair. The system has a 2" PVC conduit running the back wall with 4/0 copper. At every room they have a 30 amp disconnect for the AC in that room. The best I can tell the #10 wire is wrapped then taped to the 4/0. The disconnect box is only 8" wide so there is no room to work with the Large wires. I seldom use the tap rules, so My unserstanding of them is limited. The entire job looked sloppy to me, but I was told a licensed electrician did the install. Any help would be appriciated.
