FESApprentice2496
I'm going to try to explain this as best as possible. There is an existing 6000A switchgear in the basement of the building were remodeling. The service conductors from the power company come into the gear and land on the busbars. We are adding a second service (1600A) to the building so the owners can monitor each individual apartment's power usage. The existing switchgear is on the right side of the electrical room and the new disconnect and meter stacks on the left. On the back wall there are 3 conduits on the floor that run from the gear to the new disconnect. The pipes are being encased in concrete which is going to create a raised pad/surface in the room. Conductors are 600MCM Grounding wire is 3/0. I'm confused if I can run Black, Red, Blue, Neutral in each pipe and run one 3/0 THHN ground along the outside of the pipes so the grounding wire will be encased in concrete afterward. Or do I need to Run a ground in each pipe, so it would be Black, Red, Blue, Neutral, Ground. We were talking about it at work and going back and forth on it. i looked in the code and have read it both ways. Id like some explanation and some code articles along too.
Thanks
Thanks
