4000 amp main for a switchboard being feed as a FEEDER
Jason Ward
USA
I have a 4000amp disconnecting means (Breaker) located outside a 6 story multi-family building.
I am feeding a 4000amp 480/277v switchboard located 100' inside of the building. This is considered a "feeder".
Can it be a MLO switchboard or will it require a main?
Thanks for your time and response.
Jason Ward, P.E.
augie47
Tennessee
I believe the devil will be in the details. "Outside" being the operative word.
If the main is on the outside of the building and attached to the building (therefore 'a part of') then I see no problem.
If the main is not structurally a part of the building then, by Code definition, it can be viewed as a
structure" and Art 225 comes in to play.
The details may makw the installation an AHJ call as to his view of the ,main being a separate "structure"
Strathead
Ocala, Florida, USA
And... as an electrician, I think, "please don't" I know that lock outs are required, but it is much more comforting to have physical control of the disconnecting means when I am working on a piece of gear.
malachi constant
Minneapolis
I have put service disconnects outside adjacent to the utility transformer, not attached to the building. Never thought twice about it, never got flagged. I do this rarely but when it is on the table I always make sure the Owner is 100% on board with it. I had never thought of this as being in a gray area but augie makes a good point. I guess it makes sense to run it by the AHJ too.
Jason Ward
USA
4000 amp main
4000 amp main
Thanks. That is how i saw it. The outside disconnect is with-in arms distance from the building/structure.
I just have an overworked AHJ.
augie47
Tennessee
Sounds like with a couple of pieces of angle-iron it could be part of the structure :D
