208Y/120V 3? 4W service?
Then as Gus implied, you have three combinations of 120/208V 1? 3W: A-N-B, B-N-C, and C-N-A.Yes indeed.
Good point!!!Take it one step further because all panels are not created equal. If all the panels are 200A split-phase and carry the same load then 5-4-4 seems reasonable. But, to really balance the load, you want panel rating, or better yet, actual panel load, balanced.
yea hard call to make, cheap fix is just to even the numbers out on each phase, expensive ( but the right way) is to get recording equipment and hook it up to each apartment to see what there amperage draw is and on what phases to really do the job right or if all the apt. owners are willing to give you a copy of there last 3 months electric bill you can find the largest usage that way.
Why is it that critical to balance the loads so precise?
No one is living in this building at the moment. Why is it that critical to balance the loads so precise?
If the units are independently metered, thinking about how to divvy up the loads is not required. Modular meter stacks do it for you.
