- New Jersey
- Journeyman Electrician
Does anyone have a link so that one could read the public comments made to proposals for the next NEC code cycle?
NFPA website says... ROC Posting Date: 3/22/2013Does anyone have a link so that one could read the public comments made to proposals for the next NEC code cycle?
Don't kill the messenger :happyno:Thanks. I've visited the page in your link several times and find it as useless as their search engine. :slaphead:
I don't find that page hard to use. Not sure what you are looking for, but just scroll down to the "ROC Meeting Agendas", select the one from the CMP that you are interested in and open it or download it. These files contain all of the public comments and the initial CMP action on those comments. I believe that the panel statements and action are still subject to change as of the date that the panel agendas were posted.Thanks. I've visited the page in your link several times and find it as useless as their search engine. :slaphead:
They will be in one document after the ROC is published. Nothing that is posted now, is offical.I was looking for an aggregated document where one could search all of the comments at once without having to download 19 different documents and search them individually. Not to mention the needed information of which CMP you're search is under. IMO public comments on public documents should be a little easier for the public to find. :roll:
There is no public comment on the comments.That's what I figured but really the comments should be posted in real-time this way someone could comment on the comment before the comment period ends. :happyyes:
There has never been a way to comment on a comment, other than action on the floor at the annual meeting. This is an ANSI consensus standard and I would expect that the process is spelled out somewhere.So in other words there is no ability to comment on a comment. Is this intentional or just the way that it always been? IMO in the digital age to get the most public input the comment stage should be in real-time.
All of the comments and panel actions will be in a single pdf when they officially publish the ROP. Until then you can only look at them one panel at a time.I was just looking for an easy (substitute lazy) way to read certain comments.
I'd like to find an easy (substitute "not a pain in the @ss") way to read comments by article. Looking at some of the comments, it looks like roof-top string inverters might become nigh on impossible, if the "no more than 80 volts (which we may lower) after pressing the ESD" requirement makes it in.
Not all that easy to find, wading through all those utterly useless comments about every other article
tallgirl, what section did you read that 80volt rule in for the ESD?
Maybe the solution would be to allow an ungrounded PV array in that case, so that no point would ever be 80 volts (or any other voltage) from ground.I believe it was a proposal to create a new 690.12 section. That or a revision to 690.11.
I'm not sure how that would work for string inverters since they usually wire from panel to panel, with a home run back to the string combiner. As I read the proposal, no portion of that entire string could be above 80 volts. Since Voc on a 72 cell module is over 40 volts, that means EACH AND EVERY module would have to be individually disconnectable.
