srinivasan
- Bangalore,India
1)fan is going to use for suck the waste gas from industry and outlet will be connected to thermal oxidizer chamber. incoming gases rate is 22000 Nm3/hr. i dont know about fan design calculation. In this worst case i have to make panel inquires. without motor rating it is not possible . give me some rough calculation for fan details with this flow.
2) In same case damper valves is going to be use for control the flow of gases. which type of damper valve is good to control the flow(butter fly, pipet valve etc..). Damper valve are motorized control . how select motor rating for dampers.
3) if fan details are known.. inertia is in Nm . How to calculate HP rating for motor.
4) What is the calculation to select VFD for motors.
