bobbymari
- los angeles ca
have to refeed overhead garage. code compliance came by property and gave ok to refeed overhead. in garage there is only one receptacle and a light. my question is this. using a triplex wire and resplicing at both ends, how do you get your ground? shall i use one of the two wires as a neutral and bond the messenger wire to the conduits? its only a 120 feed. i normally do these underground so not exactly familiar with this install, underground not an option in this case
