JW 569
- San Diego, CA
I am retrofitting controls on a 4160v starter. I found that there was a CT rated at 600v, 60 hz, 200:5, around a 5kv unshielded cable, with the secondary connected to an ammeter rated at 5a f.s., 50 hz (this is a 60 hz system). While I have reservations about the CT, I can install an insulation sleeve over the cable to reduce the possibility of line potential getting to the meter.
My real question is about the meter. Is it safe or accurate at 60 hz? My opinion is that it is only as safe as the CT, but I'm not sure how, or if, frequency affects the accuracy.
If the meter is an issue, I can go to the customer and justify replacing the CT and the meter.
