915Ben
- El Paso, Texas, USA
Hello all,
I am working on an apartment remodel design where each apartment currently has a mech/elec room which houses a furnace, water heater, and electrical panel. The room has working space for all these items which the tenants have turned into storage space. The owner has asked if we can simply put a lock on the room and deny the tenants access. Going through the code I have found 110.26(G) which tells me that a locked electrical room is considered accessible to qualified persons but then I see 240.24(B) which states that all occupants (not just the qualified ones) are required to have access to overcurrent devices serving branch circuits in the occupied space. Here is where my confusion begins, 240.24(B)(2) states:
"Where electric service and electrical maintenance are provided by the building management and where these are under continuous building management supervision, the branch circuit overcurrent devices suppling any guest rooms or guest suites whith out permanent provisions for cooking shall be permitted to be accessible only to authorized personnel."
In my case I think it is pretty clear that I cannot have the panel locked away from the tenants but from this section of code, it appears to me that the only spaces in the entire world of occupied spaces that can have restriced breaker access are guest rooms and guest suites without cooking appliances. Unless I am missing something, that means that every locked electrical panel in every commercial building is in violation of 240.24(B). Is there another section of code I am missing that negates the requirements of 240.24(B) or are branch circuit breakers intended to be accessible to anyone who occupies a space? If the latter case is the intention of the code, how does one square that with hospitals, or asylums, or prisons? Any thoughts?
Thanks
Thanks
