A lot of us make up our own connection to the PoCo's triplex. When doing this, what connector should be used to connect to the steel neutral conductor on the ACSR triplex? All of the common connectors or crimps seem to only be listed for copper or aluminum.
Hmmmm, I didn't notice that. Split bolts, aluminum reducers, Ilsco Kup-L-Taps, etc. don't always have ACSR listed. I was told by another electrician that it's still ok to use them because the steal messenger cable has aluminum in it :roll:What kind are you talking about? The H tap connectors and the barrel splices are listed for ACSR.
I guess the other sparky was right when he told me that the steel cable had aluminum in it
That's what he said. The messenger cable had aluminum in it, same as you said.Not quite. The steel cable has aluminum around it, not in it.
"Sparrow" (#2 aluminum) or "Raven"(1/0 aluminum) is 6 strands of aluminum around one strand of steel in the center.
I love the wealth of knowledge on this site.
I continue to learn more and more as I continue to realize how little (in the grand scheme of things) I already know.
AROUND it, not IN it...:lol::lol::lol:
You need to watch what kind of cutters you use when cutting ACSR. Dykes, bolt cutters, and other pinching type cutters are OK, but slicing type cutters usually don't have hard enough cutting edge to take hard steel strand in an ASCR cable, and it will damage your cutter. Most of these cutters are marked to indicate they are for copper and aluminum only.
Did you learn that the hard way.... like I did? :slaphead:
"ACSR" means "Aluminum Cable, Steel Reinforced." Only the few center strands are steel- most of the wire is aluminum. That's why cutting it with cable cutters only makes a little nick in the blades.
Your connector only touches the aluminum.
