mstrlucky74
- NJ
Is most of the strut/channel that's used to support racks of conduit galvanized and why if it is used indoor?
Unistrut for one is available "plain". However, it still has the oil coating that was used during the forming process. Also, unless you're in Arizona or someplace equally dry, plain steel will start to rust at some point. The coated strut maintains a cleaner appearance over time.
And if you cut the coated, you should have a can of cold gal for the galvanized ends, maybe just primer for plated?
So which one is used most frequently for indoor conduit(s) support?
painted
painted
Most of what we use is plated but sometimes we use the forest green painted kind.
a lot of it depends on what flavor the wholesale house is stocking.
(snip)
when you get to honest galvanized, it's usually in a refinery, etc.
sewage and food packing is stainless, with stainless straps.
Not so much, our purchaser will get me whatever I ask for.
For large quantities we don't even buy it from an electrical supply house, we get it from a steel company in 20' lengths.
