Load Side Meter Wires
Cavie
SW Florida
Every meter can I've installed in my 40 years has had factory ko's in the Top, Bottom and Sides. The sides will be below the wire lugs. The top will require a WP hub.
fmtjfw
Can the pipe/wire enter the side of the meter pan?
If the meter socket is a 3R enclosure you will probably find knockouts on the lower part of the sides and back. By design these are below the lugs. 3R allows the wire to get wet (since it should be rated for wet locations if outdoors) and does not allow the lugs to get wet.
